I just noticed that several things that I have dragged to “Inbox” in my Finder Sidebar haven’t been showing up in my DT Inbox. I determined that the items are going into the DT2 Inbox folder not the DT3 inbox folder. Two questions:
Can I just remove the Inbox from my Finder sidebar and then drag the DT3 Inbox to the side bar without any undesirable side effects?
Can I delete the entire DT2 folder in ~Library/Applications Support?
(I have been running DT3 for a couple of months (or so) but didn’t notice the problem because I mostly use my iMac and that seems to be working correctly, but I am currently traveling with my MBP and that’s where the wrong folder is used).
DEVONthink 2 and 3 use different Inboxes. You find the Inbox of Version 2 here:
~/Library/Application Support/DEVONthink Pro 2/
and the Inbox of version 3 here:
~/Library/Application Support/DEVONthink 3/
Drag the Inbox (Inbox.dtBase2) you find in
to the finder, open it as a Database and move the content wherever you want. Afterwards you can delete that Inbox. Then delete the Link in the finder sidebar and replace it with the Inbox for DEVONthink 3 (You can just drag the Inbox into the finder sidebar. Or use DEVONthink 3 > Install Add-Ons
Also, you should not run DEVONthink 2 and 3 on the same account, on the same machine. At a minimum, you should delete DEVONthink 2.x from the /Applications folder and reboot the machine.
Thanks to both of you – but I don’t think that I actually get an answer to either of my questions
Clearly I knew where all of those folders are since I refer to both of them in my original question.
The DT2 was long removed from my Application folder and I am sure the machine has been rebooted several times since then (although I don’t reboot often).
So let me try again.
Can I just remove the (old) Inbox from my Finder sidebar and then drag the DT3 Inbox to the side bar without any undesirable side effects?
Thanks
Great… Thanks. I have already moved all of the Inbox stuff to the DT3 Inbox so I think I am all set there.
