Incoming and outgoing [[wikilinks]] are reflected in the “Links” tab of the Document inspector panel alongside [devonthink](x-devonthink-item://item-links), but unlike those, incoming and outgoing wikilinks aren’t counted in the corresponding columns in my database, or for purposes of smart groups. Is this a setting or expected behavior? For folks who use wikilinks heavily, as I do, this would be fantastic functionality.
Wiki links are not indexed but only calculated on the fly whenever necessary. That’s e.g. no problem when viewing/editing documents or using the Document > Links inspector but would not be useful for such a column or even smart groups and therefore is currently not possible.
The advantage of the current approach is that it doesn’t waste disk space & CPU time and everything’s immediately up-to-date after changing settings or renaming/editing/creating/deleting items etc.
Anyway, which Wiki link style do you use? Square brackets? In this simple case a small script & a smart rule could automatically calculate the values after importing/editing documents. This doesn’t cover all shortcomings but depending on your usage scenario this might be sufficient if links are usually just added by importing/editing documents.
Here’s a basic example:
on run
tell application id "DNtp" to my performSmartRule(selected records)
end run
-- 1. Update number of incoming/outgoing Wiki links of created/imported/edited document first
set outgoingLinks to outgoing Wiki references of theRecord
set numOutgoingLinks to count of outgoingLinks
add custom meta data numOutgoingLinks for "outgoingwikilinks" to theRecord
set numIncomingLinks to count of incoming Wiki references of theRecord
add custom meta data numIncomingLinks for "incomingwikilinks" to theRecord
-- 2. Update number of incoming Wiki links of referenced documents
repeat with theLink in outgoingLinks
set numIncomingLinks to count of incoming Wiki references of theLink
add custom meta data numIncomingLinks for "incomingwikilinks" to theLink
end performSmartRule
And the smart rule could look like this:
Clever-- thank you!
