I’m using this script to replace attachments in e-mails with DT links. I noticed that those DT links (added by editing the .eml file) don’t show up in the Incoming Links section of the target item (an attachment imported into DT).
At first I thought this might be because I edited the .eml file post-import. But some testing showed that also when the DT link is in the e-mail on import (with a Test database) it doesn’t show an Incoming Link in the target item.
Is this intended behavior (are e-mails not scanned for possible incoming / outgoing links)? The outgoing DT link shows up in the Links section of the e-mail just fine. Also when I convert the e-mail to RTF, a PDF document or a web archive - the Incoming Link is displayed.
Thanks. I would greatly appreciate if Links in e-mails would be detected. All other formats I’ve tested work (RTF, PDF, Microsoft Word etc) so not directly clear why they’re not working in e-mails.
Only those formats (HTML, web archive, formatted notes, PDF, Markdown, plain/rich text and sheets) which can be edited in DEVONthink and support cross linking are currently scanned.
To understand: is this because of performance or other reasons? What’s interesting is that apparently Microsoft Word documents are scanned - is this because Word documents are (somewhat) similar to RTF?
