I don’t quite understand the difference between “incoming item links” and “incoming links”. Wiki links are activated for my DEVONthink databases. I see a few hundred incoming links in the item inspector for a document but no incoming item links in the list view for the document.
I would love to see the actual number of incoming links to a document in the list view.
Have you read the Documentation > Documents > Document Linking section of the built-in Help and manual?
thanks for the clarification!
As the “incoming links” part of the inspector window lists item and wiki links I would suggest to change the text in this part if there are no links to “no incoming links” instead of “no incoming item links”
Thank you for the suggestion, the next release will change this.
