Maybe we can do this in pieces. Here’s a hack of Rob’s script that will create a project in DTPO according to the tree in OF2.
Edit: code improved by unlocked2412 on OmniFocus forum https://discourse.omnigroup.com/t/integrating-omnifocus-2-with-devonthink-pro-rob-trew-scripts/26100/6 to paste DTPO group link in note of OmniFocus project.
property pblnJustFolder : true
property pblnUseSyncAsRoot : false
-- Robin Trew
-- ver .204 June 19 2011
-- Aug 22 2011
-- Ver .208 Still defaults to the DT Database named in pstrDTDB (below)
-- but can use different DT databases for different OF folders
-- (will use the first existing DT database whose POSIX path is found in the note of an enclosing OmniFocus folder
-- [a script for editing OF folder notes can be found at
-- http://forums.omnigroup.com/showthread.php?t=21942]
-- ver .211 Sep 12 2011
-- Adds option, above - top of script, to make the Sync group the root of all new folders
-- Disclaimer
-- This is just a rough draft of something which I have sketched for my own personal use,
-- and which is provided purely as an illustration of possible approaches to coding.
-- You are free to adapt and reuse any part of it, without any warranties, implied
-- or explicit, as to its behaviour or suitability for use
-- IF property pblnJustFolder : **false** (see top of script)
-- CREATES/OPENS A PROJECT NOTES FILE (STORED IN DEVONthink 2) FOR THE SELECTED OMNIFOCUS PROJECT.
-- 1. The project notes file is an OmniOutliner 5 document stored in DEVONthink 2 folder
-- 2. The Devonthink record contains a hyperlink back to the OmniFocus project
-- 2. The script ensures that a DT hyperlink to the document in DevonThink is placed in the note field of the project
-- 3. In the absence of a link to existing notes in DevonThink,
-- the script will seek or create the OO5 file in a DevonThink folder which matches
-- the folder path of the project in OmniFocus
-- (and add the hyperlinks from project to notes, and from folder and notes to project)
-- OR - IF property pblnJustFolder : **true** (see top of script)
-- JUST CREATES/OPENS A PROJECT MATERIALS FOLDER (IN DEVONthink 2)
-- FOR THE SELECTED OMNIFOCUS PROJECT.
-- 1. The script ensures that a DT hyperlink to the document in DevonThink is placed in
-- the note field of the project
-- 2. In the absence of a link to an existing folder in DevonThink,
-- the script will add the hyperlinks from project to folder, and from folder to project)
-- Acknowledgements
-- Inspired by Jim Harrison's excellent scripts, which use the Finder rather than DEVONthink 2
-- http://jhh.med.virginia.edu/main/OmniFocusScripts
-- The icon attached to this file is from the Float collection by Corey Marion
-- http://iconfactory.com/freeware/preview/flot
-- GLOBAL CONSTANTS
-- Initially assumes that project folders will be maintained in
-- a database named [UserName]/Documents/Omnifocus Notes.
-- Edit the name and path below to change the location and/or name
--of the main Projects folder that will contain the individual project folders
property pstrDTDB : "OmniFocus Notes" -- name of default Devonthink Database
property pstrDTsuffix : ".dtBase2"
property pstrDocsPath : (path to documents folder as string) -- path to ~/Documents
property pstrSync : "/Sync"
property pstrOO5Template : "Default"
property pstrOO5Suffix : ".ooutline"
property pstrOFPrefix : "omnifocus:///task/"
property pstrXMLPrefix : "<value key=\"link\">"
property pstrRunDelim : "</lit></run>"
property pstrDTPrefix : "x-devonthink-item://"
property pstrDBPath : "$HOME/Library/Containers/com.omnigroup.OmniFocus2/Data/Library/Caches/com.omnigroup.OmniFocus2/OmniFocusDatabase2"
--property pstrDBPath : "/Users/detach/Library/Containers/com.omnigroup.OmniFocus2.MacAppStore/Data/Library/Caches/com.omnigroup.OmniFocus2.MacAppStore/OmniFocusDatabase2"
property pstrFolderLinkTitle : "[Devonthink folder for this project]"
property pstrNoteLinkTitle : "[Devonthink ooutline notes]"
property plngURLchars : 36
on run
-- IS A PROJECT (OR ONE OF ITS TASKS) SELECTED IN OMNIFOCUS ?
set {oProject, strProjName, strProjID} to GetSeldProject()
if oProject is missing value then return
-- IS THERE A RELEVANT LINK IN THE NOTE FIELD OF THE PROJECT ?
set {strFolderURL, stroo5URL} to DTLinksInNote(oProject)
-- AND IF SO, DOES IT LEAD ANYWHERE ?
if pblnJustFolder then
if strFolderURL ≠ "" then if FollowDTLink(strFolderURL) then return
else
if stroo5URL ≠ "" then if FollowDTLink(stroo5URL) then return
-- IN THE ABSENCE OF A LIVE DT LINK, CREATE OR FIND A MATCHING FOLDER PATH IN DT
set oDTFolder to my GetParallelFolder(oProject)
set strDTLink to reference URL of oDTFolder
else
-- CREATE OR FIND A NOTE FILE FOR THIS PROJECT
set strNoteName to "• " & strProjName & " notes" & pstrOO5Suffix
set recNotes to my GetNotes(oDTFolder, strNoteName, strProjID)
set strDTLink to reference URL of recNotes
-- DT REFERENCE URL TO OF PROJECT NOTE: unlocked2412
tell application "OmniFocus"
tell front document
set note of oProject to strDTLink
-- PLACE AN RTF-FORMATTED DT LINK TO THE NEW OR PRE-EXISTING NOTES IN THE NOTES FIELD OF THE PROJECT
set strLinkTitle to pstrFolderLinkTitle
else
set strLinkTitle to pstrNoteLinkTitle
my PasteToNote(oProject, strLinkTitle, strDTLink)
-- AND FOLLOW THE LINK TO THE FOLDER OR OO5 DOCUMENT IN DT2
FollowDTLink(strDTLink)
tell application id "DNtp" to activate
end run
-- Return the first project selected in the Omnifocus GUI
on GetSeldProject()
tell front document
-- GET THE FIRST SELECTED PROJECT (CONTENT OR SIDEBAR)
if (count of document windows) < 1 then return {missing value, "", ""}
tell front document window
set oProject to missing value
repeat with oPanel in {content, sidebar}
set lstSelns to (value of selected trees of oPanel where (class of value = task) or (class of value = project))
if (count of lstSelns) > 0 then
set oProject to first item of lstSelns
exit repeat
if oProject is missing value then return {missing value, "", ""}
if class of oProject = task then set oProject to containing project of oProject
tell oProject to return {it, name, id}
end GetSeldProject
on DTLinksInNote(oProject)
-- DOES ITS NOTE CONTAIN A DEVONTHINK URL ?
set strQuery to "select CAST(notexmldata as text) from task where persistentIdentifier = \"" & (id of oProject) & "\""
set strNoteXML to do shell script "sqlite3 " & pstrDBPath & space & quoted form of strQuery
set strLink to pstrXMLPrefix & pstrDTPrefix
set blnOpened to false
if strNoteXML contains strLink then
set {strDlm, my text item delimiters} to {my text item delimiters, pstrRunDelim}
set lstRuns to text items of strNoteXML
set my text item delimiters to "<lit>"
set {blnFolder, blnNote} to {false, false}
set {strFolderURL, strNotesURL} to {"", ""}
set strStart to text 1 thru 2 of pstrNoteLinkTitle
repeat with oRun in lstRuns
set lstSections to text items of oRun
if length of lstSections > 1 then
set strLabel to item -1 of lstSections
set strPreamble to item -2 of lstSections
if strLabel begins with strStart then
if not blnFolder then
if strLabel contains "folder" then
set strFolderURL to my ParseLink(strPreamble)
if strFolderURL ≠ "" then set blnFolder to true
if not blnNote then
if strLabel contains "notes" then
set strNotesURL to my ParseLink(strPreamble)
if strNotesURL ≠ "" then set blnNotes to true
if blnFolder and blnNote then exit repeat
set my text item delimiters to strDlm
return {strFolderURL, strNotesURL}
else
if note of oProject = "" then set note of oProject to space -- (seems to prepare note for easier opening later)
return {"", ""}
end DTLinksInNote
on ParseLink(strXML)
set {strDlm, my text item delimiters} to {my text item delimiters, pstrXMLPrefix & pstrDTPrefix}
set lstParts to text items of strXML
set strURL to ""
if length of lstParts > 1 then
set my text item delimiters to "</value>"
set strURL to first text item of item 2 of lstParts
if length of strURL = plngURLchars then
set strURL to pstrDTPrefix & strURL
else
set strURL to ""
return strURL
end ParseLink
on FollowDTLink(strURL)
if strURL ≠ "" then
set blnOpened to (do shell script "open " & quoted form of strURL) = ""
if blnOpened then
return true
else
return false
else
return false
end FollowDTLink
on GetParallelFolder(oProject)
set {strPath, strFolderDB, strProject} to GetProjPath(oProject)
-- CHOOSE THE TARGET DATABASE
-- EITHER FROM A PATH IN THE ENCLOSING FOLDER, OR FROM THE DEFAULT
if strFolderDB ≠ "" then
set strDb to strFolderDB
else
set strDb to (POSIX path of pstrDocsPath) & pstrDTDB & pstrDTsuffix
set oDb to open database strDb
if oDb is missing value then
set oAnswer to display dialog "Create new Devonthink database at \"" & strDb & "\" ?" buttons {"Cancel", "OK"} default button 1
if the button returned of oAnswer is "Cancel" then return
set oDb to create database strDb
-- DEPENDING ON GLOBAL SETTING, OPTIONALLY CREATE NEW FOLDER WITHIN SYNC GROUP
if pblnUseSyncAsRoot then
set oLocn to create location pstrSync & strPath in oDb
else
set oLocn to create location strPath in oDb
set URL of oLocn to pstrOFPrefix & (id of oProject)
return oLocn
end GetParallelFolder
on GetProjPath(oProject)
set strProject to name of oProject
set strPath to strProject
set oContainer to container of oProject
set blnFolderFound to false
set strFolderDB to ""
set cClass to the class of oContainer
repeat while cClass is not document
if not blnFolderFound then
if cClass is folder then
set strFolderDB to note of oContainer
if ((strFolderDB ends with pstrDTsuffix) and my FileExists(strFolderDB)) then set blnFolderFound to true
set strPath to name of oContainer & "/" & strPath
set oContainer to container of oContainer
return {"/" & strPath, strFolderDB, strProject}
end GetProjPath
on GetNotes(oDTFolder, strNoteFile, strProjectID)
set lstNoteRecs to children of oDTFolder where name = strNoteFile
if length of lstNoteRecs > 0 then
return first item of lstNoteRecs
else
-- IMPORT A FRESH TEMPLATE FILE FROM THE SAME FOLDER AS THIS SCRIPT
tell application id "MACS" to set oScriptFolder to container of file (path to me)
set strScriptFolder to POSIX path of (oScriptFolder as alias)
set strTemplate to strScriptFolder & pstrOO5Template & pstrOO5Suffix
if my BundleExists(strTemplate) or my FileExists(strTemplate) then
set oRec to import strTemplate to oDTFolder
else
-- OR FROM INSIDE THE SCRIPT BUNDLE
set strTemplate to POSIX path of (path to me) & pstrOO5Template & pstrOO5Suffix
on error
display alert pstrOOTemplate & " not found in this script bundle"
return missing value
tell oRec
if it is missing value then return it
set its name to strNoteFile
set its URL to pstrOFPrefix & strProjectID
return oRec
end GetNotes
on FileExists(strPath)
(do shell script ("test -e " & quoted form of strPath & "; echo $?")) = "0"
end FileExists
on BundleExists(strPath)
(do shell script ("test -d " & quoted form of strPath & "; echo $?")) = "0"
end BundleExists
