Does anyone know if there’s any way to interface DevonThink w/ FileMaker Pro? That is, apart from exporting a FMP into an Excel or a PDF, and then opening it in DevonThink…
Thanks!
Thanks!
Um, Applescript?
Ok… In what way can AppleScript enable a FileMaker Pro database to become accessible to DT?
Any suggestions…?
I don’t think there are any mind readers here on the forum, so until you propose something you want to do with these two pieces of software, I doubt you’ll get anyone to describe the effectively infinite number of possibilities there are.
Alternatively, you could take a look at FMP and DTPO’s dictionaries in the Applescript editor and see for yourself.
Charles
I’m trying to find a way that FileMaker Pro & DEVONthink can communicate w/ each other (i.e., interface) so that I can access the data / info contained in my FileMaker Pro database – just like the way DEVONthink is able to access / import / index data from other formats (e.g., from email clients).
Is this possible? If so, how?
Thanks!
I’ve been asking around in a FileMaker Pro forum, and was told that in order for FMP to access / interface w/ a DEVONthink database FMP would need specific ODBC drivers to access from the DEVONthink database… Possible?
Thanks!
DEVONthink doesn’t use or support ODBC. Therefore the only solutions are either AppleScript or ex- & importing CSV/TSV files.
I’ve never used AppleScript before. How would you suggest I use it? Is there a kind of script you’d suggest I produce that would enable this kind of interfacing? Thanks for your help!
I don’t use FileMaker, therefore I don’t know.
You can look in your Filemaker Documentation for the discussion of “Perform Applescript,” p. 139:
http://www.filemaker.com/downloads/pdf/fmp10_scripts_reference.pdf
You’ll be interested in everything else that document has to say.
Hanaan Rosenthals’s book on Applescript also has a section of Filemaker:
http://www.apress.com/book/preview/9781590596531
See page 635 of the Apress preview.
Thanks very much. But I was wondering if there were suggested AppleScripts already out there that I might be to try out – anything already created that helps DT to interface w/ FMP. Thanks!
