I have started to make a more intense use of icons to differentiate records, so my idea is to create prototypes (like one would in Tinderbox) and apply them via AppleScript. Is is possible?
Aha! Thanks a lot, Jim @BLUEFROG.
I kept looking for the term icon in the dictionary to no avail.
You’re welcome
PS: the best option is to look at the properties of the element - in this case a record- in the dictionary first. There you can see all the properties available.
Thanks for the tip! That is indeed the best option! Script debugger even has a nice “Copy reference” feature
By the way, were it not for you encouragement (many months ago) I would not have learned the first thing about Applescript. Now I love it
Thanks for the kind words and I’m glad to have helped along the way!
I’m hoping to find more time for it again.
PS: If by protoype you mean template, note you can apply a custom thumbnail to a file and export it as a simple template. That icon should be preserved when you import the template.
Of course, for smart templates, the AppleScript can also come in handy.
Same here ![]()
I use this to set icons from a predefined list of icons or from a file.
-- Set record icon from list
property Item_1 : "Orange"
property item_1_path : "/Users/user/Library/Application Support/DEVONthink 3/DEVONthink 3 eigene Icons/Status Icons/DEVONthink 3 Group_orange.png"
property Item_2 : "GrĂĽn"
property item_2_path : "/Users/user/Library/Application Support/DEVONthink 3/DEVONthink 3 eigene Icons/Status Icons/DEVONthink 3 Group_green.png"
property Item_3 : "Rot"
property item_3_path : "/Users/user/Library/Application Support/DEVONthink 3/DEVONthink 3 eigene Icons/Status Icons/DEVONthink 3 Group_red.png"
property Item_4 : "Datei"
tell application "System Events" to set activeApp to name of first application process whose frontmost is true
tell application "SystemUIServer"
activate
set theChoice to choose from list {Item_1, Item_2, Item_3, Item_4} default items {Item_1} with title "DEVONthink Icon" with prompt "Icons setzen"
if theChoice is false then return
activate application activeApp
if item 1 of theChoice = Item_1 then
set thumb to POSIX file item_1_path as alias
else if item 1 of theChoice = Item_2 then
set thumb to POSIX file item_2_path as alias
else if item 1 of theChoice = Item_3 then
set thumb to POSIX file item_3_path as alias
else if item 1 of theChoice = Item_4 then
set thumb to choose file of type {"jpg", "png", "tiff"} default location POSIX path of (path to pictures folder from user domain)
repeat with thisRecord in (selection as list)
set thumbnail of thisRecord to (POSIX path of thumb)
Nice, @pete31! Thanks for sharing. I will give it a try. My solution so far had been to use a KM Macro to pass the variables (prototype name and icon) to the AppleScript, but yours look more economic.
You certainly did. You and Mr. Grunenberg (@cgrunenberg ). ![]()
Oh, by the way: I noticed something funny while setting the thumbnail via AppleScript. See the little white box around the icon? It always shows on the list view, but not in the inspector. If I copy and paste it again from the inspector, it disappears.
Sounds like a bug, we’ll check this.
@pete31 it’s been a while since you posted it, but thanks for the script!
Is there any chance that this could be transformed into a Smart Rule script?
I’m thinking along the lines of automatically changing icons e.g. based on a certain tag or other attribute.
No, as this script needs user interaction (and Smart Rule scripts run automatically).
This Smart Rule script sets a thumbnail. Should be easy to adjust it to your needs.
As you’re into customizing thumbnails you’ll probalby also want to take a look at Script: Colorize DEVONthink Icons (Color Code Magick).
For me it’s one of the most useful scripts as it makes finding groups (e.g. in the navigation sidebar) a lot faster. Instead of searching for the name it’s just one look and I know “Ah, this is what I want”.
Wow, the script in your first link is exactly what I was looking for! Thank you!
Set it up with a SmartRule after changing the code to link to a local icon file and it’s working perfectly.
The second script also looks really interesting but seems to need a bit more setup. Will bookmark it for the next iteration of optimizing icons, sometime in the future
