Hello,
If I am reading PDF and making annotations with a highlighter, the only way I found to vertical scroll is to turn the highlighter off → scroll → resume annotating with highlighter, Is there a way to vertical scroll with an annotation tool (highlighter or other) active ?
thank you
Does scrolling up and down with two fingers work for you?
thank you for your post
DTTG latest version
iPad Pro, iOS 14.8
If I have the highlighter active (hard press on highlighter icon)
when I scroll up and down with 2 fingers, large sections of text become highlighted at the same time. I tried restart ipad, quit → restart DevonThink.
when the highlighter is active, sometimes text is highlighted automatically when I select it and sometimes a contextual menu appears. I have not found a way to make one or the other a default (could not find it in DTTG settings)
thanks again
OK, I see what you mean. This is something that the PDF engine we’re using does all by itself. Noted as a feature request/bug report.
thank you
