Hi, I’m fairly new to Devonthink Pro and am looking for a way that could achieve the above, when I import a document it will automatically add the document creation date to the first part of the title.
Is this possible? I have done a search through the forum and see there are quite a few old posts on the subject that I have tried to follow but in the end they are too complicated.
Could someone point me in the direction of an easy to follow way of getting this to happen?
Yes that looks like just what I am after, simple and easy to do. Just one question, how do I get the “Sortable Creation Date” to input? If I just type it in, it doesn’t let me save the rule. Is this something I have to enable in settings?
I have already used the search function and yes it came up with loads of results but I found it difficult to understand any of them, I’m new to Devonthink and found the posts I found hard to follow. That’s why I started a new thread, not ideal but I couldn’t understand what half the posts were doing with Apple Scripts etc.
