JavaScript: Preserving the TOC through OCR – a shorter solution
@clang proposed an AppleScript script that preserves the table of contents through OCR about two years ago:
I took the liberty to re-write that in JavaScript which resulted in a shorter script and avoids running external programs as well as creating temporary files outside of DT as the original did.
ObjC.import('PDFKit');
  const records = app.selectedRecords();
  records.filter(r => r.type() === 'PDF document').forEach( r => {
    /* Loop over all selected PDF documents */
    const path = r.path();
    /* get a PDFDocument object for the old PDF */
    const PDFDoc = $.PDFDocument.alloc.initWithURL($.NSURL.fileURLWithPath($(path)));
    /* get the old PDF's TOC ("outlineRoot" in Apple parlance) */
    const TOC = PDFDoc.outlineRoot;
    /* OCR the record. The timeout was enough for a 544p book */
    const newRecord = app.ocr(path, { file: path, to: r.locationGroup(), waitingForReply: true},
         {timeout: 1200});
	const newPath = newRecord.path();
    /* get the PDFDocument of the OCRd record */
    const newPDFDoc = $.PDFDocument.alloc.initWithURL($.NSURL.fileURLWithPath($(newPath)));
    /* Set the new PDFDocument's TOC to the old one's */
    newPDFDoc.outlineRoot = TOC;
    /* Persist the new PDFDocument */
    newPDFDoc.writeToFile($(newPath));
    /* Uncomment the next line to delete the old record */
//   app.delete(r);
The latest version of the OCR engine actually retains the table of contents. Do you use Intel or Apple Silicon Macs?
I’m on Apple silicon. And this was just a programming exercise for me – the few PDFs with a TOC that I have always come with a text layer.
What’s the difference between the two? My desktop is Intel-based but my laptop is Apple Silicon.
I think you are suggesting OCR turns out superior with DT when using an Apple Silicon machine?
Not at all. Just usual questions to reproduce things.
