I use tags and flags extensively, colours less so.
1 Work database,
Colours I use for Groups that are currently active. I have considered not having a separate database for archived work but the combined number of groups would be too long for ease of use.
I use sorter before answering a call so as to record the day/time log, then in ‘Name’ - enter the date (using TypeExpander) and details - then make notes during the call - then tag the item. Format: rich text. Location is the database Inbox.
I only use Groups for records containing fixed information concerning the particular matter. Otherwise Group is akin to a visual separator between different matters and a time-saving repository for achieving.
The location of all items is the database inbox. For each matter, I have Smart Groups that are geared to the tag I enter on the record.
I use flags where I need to do something with the information after the call is ended or for listing the important matters that need attending to. I have a central Smart Group for all items that are flagged.
- Law Library and Research
It is in my law library and research databases that I find tags come into their own. When searching for something in particular, I tag the resultant record with my abbreviation (which tallies with the tag in the work database) for the matter. For example, KL26. In a central Smart Group I add the parameter tag KL26 so for current and future use of the results of my search for KL26.
With legislation, UK Acts of Parliament, etc, a tag of the section and sub-section is useful, for example s24(1). To avoid duplicates where the same section number is in different legislation, I add another tag with my abbreviation for the Act. Also I use Smart Group to find amongst the thousands of records and indexed pdfs any of s24(1) , section 24 (1), so that I can manually add the tags.
(I understand the reason for each database having its own tags but frankly I find it a nuisance where the content of different databases is ‘linked’.)
Currently. I am saving info on Coronavirus where relevant to my work. In my research database, I have smart groups for Time Lines. Each relevant record is tagged TL and the year. I have a central smart group for all items tagged TL and separate Time Line smart groups for each year of a time line.
