Hi,
I’m trying to link references (in journal article PDFs) to their DEVONthink documents (also PDFs), however when I go to Incoming Links in the linked document, the PDF that I annotated does not show up.
Here are two screenshots to illustrate:
So here, I’ve selected text in the document Rajan, H. (2018). and used Link To in the right-click menu to add a link to another document Leung, L. C. (2011).. Both these files are PDFs and are in the Inbox of the database Research.
However, when I go to Incoming Links in the document Leung, L. C. (2011)., there’s nothing there. I expect to see an incoming link from Rajan, H. (2018).
I’ve tried linking both using the Link To menu option, as well as using the PDF annotation Link tool to manually add the item link, but same results: The link shows up in Outgoing Links of the PDF where the link is created, but not in Incoming Links of the PDF that was linked to.
This is the first time I’m trying this, so I’m not sure if it had worked before, but I assumed that this should be expected behaviour, unless I’m mistaken?
The reason I’m doing this is so that I can build and see where journal articles I have are cited in my database through Incoming Links.
Appreciate any advice, thanks, and please let me know if I can provide any more information!
