I am confused with location with location group . When I tried to create location , I understand a group/record is created.
set theGroup to create location "/TestGroup/" in database "Test"
Base on the dictionary, I thought with location , I will be able to get the POSIX path of the group/record, ie /TestGroup/
But, instead, I am getting “/” as location and “test” (lowercase) as location group . path is also not getting the POSIX path.
So, what is a location and what is a location group ? How can I get the POSIX path of the group/record?
A group is a logical concept, not a folder . It has no physical path.
Why do you think you need that path?
TonyLim:
The location of this group is indeed /
, it’s located at the root of the database.
So, for any operation with the group you need just UUID of this group. Only indexed group may have a real path in filesystem.
I can understand that this group is located at /
, the root of the database. What is location group ? location group is “test”, the database?
Yes, the location group
is the root of the database in this case.
Hmm…so the root of the database is test
, the database itself?
meowky
August 26, 2024, 1:39am
8
Not really. The database itself is a database
. The root of it is a record
If the group is deep in the hierarchy (like, /TestGroup/SubGroup/Sub-SubGroup), it will be easier to figure out where it is if I need to traverse the path/hierarchy.
No. But the root’s name is the one of the database.
