Hi,
wie kann ich das fertige Appleskript von DT bezüglich der Speicherung der E-Mail so ändern das ich es in die Datenbank (z.B. “Testdatenbank”) und den darin enthaltenen Ordner (z.B. “Testordner”) ablegen kann.
Das Skript legt nämlich die E-Mail nur in den globalen Eingang.
-- Mail Rule - Add messages to DEVONthink
-- Created by Christian Grunenberg on Mon Apr 19 2004.
-- Copyright (c) 2004-2020. All rights reserved.
-- this string is used when the message subject is empty
property pNoSubjectString : "(no subject)"
using terms from application "Mail"
on perform mail action with messages theMessages for rule theRule
tell application "Mail"
repeat with theMessage in theMessages
tell theMessage
set {theDateReceived, theDateSent, theSender, theSubject, theSource, theReadFlag} to {the date received, the date sent, the sender, subject, the source, the read status}
if theSubject is equal to "" then set theSubject to pNoSubjectString
set theRecord to create record with {name:theSubject & ".eml", type:unknown, creation date:theDateSent, modification date:theDateReceived, URL:theSender, source:(theSource as string), unread:(not theReadFlag)} in incoming group
perform smart rule trigger import event record theRecord
end perform mail action with messages
end using terms from
Ich denke das ich den Ablageort hier bestimmen muss:
Aber was nehme ich dann hier anstelle von “incoming group”
VG
Clamsy
