This script is deprecated – the Create Table of Contents command, added in newer versions of DEVONthink, does essentially the same thing. There are also UTF issues here that I have no interest in fixing. Please IGNORE this thread.
v1.20131108.korm
Put an index of the selected documents into a new RTF file in the current group
-- if a label is desired for the index file change this property to an integer from 1 to 7, corresponding to the configured label in DEVONthink
property p_label : 0
-- if you wish to be prompted for the destination for the index file, change this property to true
property ask_destination : false
set theSelection to selection
if theSelection is {} then error "Select an item, please"
set o_HTML to ""
repeat with thisItem in theSelection
set thisName to the name of thisItem
set thisURL to the reference URL of thisItem
set o_HTML to o_HTML & quoted form of ("<font face=\"helvetica\"><a href=\"" & thisURL & "\">" & thisName & "</a></font> </br>")
set o_RTFLink to (do shell script "echo " & o_HTML & " | textutil -format html -convert rtf -stdin -stdout" as rich text)
set defaultIndex to "01 Contents Index " & (the name of the current group)
set documentName to text returned of (display dialog "Please enter the new file name " default answer defaultIndex with title "Name of File?")
if ask_destination then
create record with {name:documentName, rich text:o_RTFLink, label:p_label, type:rtf} in display group selector
else
create record with {name:documentName, rich text:o_RTFLink, label:p_label, type:rtf} in the current group
There are seven labels possible in DEVONthink (DEVONthink > Preferences > Labels). Scripts can add labels. In the script posted above change the property p_labelto an integer from 1 to 7, corresponding the the 1st through 7th labels in the Labels configuration. Set the property to some other integer (prefer zero) if no label is desired. The default is no label.
I’m afraid you have somehow mangled the code when you copied it. I can’t help fix what I can’t see, because I can’t see what you pasted into AppleScript Editor.
tell application id “com.devon-technologies.thinkpro2”
if theSelection is {} then error “Select an item, please”
set o_HTML to ""
else
Look, you need to copy all of the code that’s posted for these scripts, not some of it.
Please, go back to the top posting in this thread. Look for this:
Press “Select All”. Everything will be in blue. Press command-c (Copy). Go to a new document in AppleScript Editor. Press command-v (Paste). Compile. Save. Run.
Your label question was answered twice, above – in the comments in the code and in my second posting.
Absolutely wonderful I have got it to run just as I wanted. Many thanks for doing this & your patience with me & appologies for my ignorance. Very grateful thanks, Andrew
