BONSAI
September 18, 2021, 7:29pm
1
Hi, i have a problem with markdown css style. I get different results in DEVONthink 3 and DEVONthink To Go. In DEVONthink 3, the table is presented as expected. In DEVONthink To Go the header is displayed in a different color and it is not possible to change the header background color.
What can i do to change the table header background color in DEVONthink To Go?
Markdown document
<Style>
table, td, th {background-color:red;}
</style>
<table>
<tr>
<th>
NewHeader
</th>
<th>
NewHeader
</th>
</tr>
<tr>
<td>
NewRow
</td>
<td>
NewRow
</td>
</tr>
<tr>
<td>
NewRow
</td>
<td>
NewRow
</td>
</tr>
</table>
| NewHeader | NewHeader |
| NewRow | NewRow |
| NewRow | NewRow |
MacOS DEVONthink 3.72
iOS DEVONthink To Go 3.2
The internal stylesheet in DEVONthink and DEVONthink To Go arenβt the same. Iβll test to see if I can reproduce the same issue here.
On a side note: Why are you creating a Markdown document and putting an HTML table in it?
BONSAI
September 19, 2021, 6:01am
3
I use the markdown syntax wherever i can, and when the markdown reaches its limits, i use html with css. To make my markdown lists look a bit nicer, i use html with css. This way i can use my own icons and styles. For tables in this list objects i need html with css.
As a markdown editor on the Mac i use Microsoft Visual Studio Code, there you can create your own extension in which you can create snippets. So it is very easy to use the html code in markdown.
On the iPhone you can use the shortcuts app to copy and paste html code into DEVONthink To Go.
HTML CSS List example
<style>
/* ββββββββββββ List ββββββββββββ */
ul,
ol {
margin-bottom: 0.7em;
/* ββββββββββββ BulletList ββββββββββββ */
ul {
list-style: none;
margin-left: -1.5em;
ul li::before {
/* Add content: "\2022" "\25CF" "\2B24" is the CSS Code/unicode for a bullet */
content: "\25CF";
color: var(--text-header-color);
font-weight: bold;
font-size: 1.2em;
display: inline-block;
width: 1em;
margin-left: -1em;
/* ββββββββββββ SymbolList ββββββββββββ */
ul.symbollist, ul.tasklist {
list-style: none;
margin-left: 0em;
li.symbollistnone::before,
li.symbollistnew::before,
li.symbollistfix::before,
li.symbollistchanged::before,
li.symbollistissues::before,
li.symbollistadd::before,
li.symbollistdelete::before,
li.unchecked::before,
li.checked::before,
li.deletetask::before {
margin-left: -2.2em;
margin-right: 1em;
align-content: center;
vertical-align: middle;
background-size: contain;
background-repeat: no-repeat;
li.symbollistnone::before, li.unchecked::before {
content: url('data:image/svg+xml;base64,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');
li.symbollistnew::before {
content: url('data:image/svg+xml;base64,PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiIHN0YW5kYWxvbmU9Im5vIj8+PCFET0NUWVBFIHN2ZyBQVUJMSUMgIi0vL1czQy8vRFREIFNWRyAxLjEvL0VOIiAiaHR0cDovL3d3dy53My5vcmcvR3JhcGhpY3MvU1ZHLzEuMS9EVEQvc3ZnMTEuZHRkIj48c3ZnIHdpZHRoPSIxMDAlIiBoZWlnaHQ9IjEwMCUiIHZpZXdCb3g9IjAgMCAxNiAxNiIgdmVyc2lvbj0iMS4xIiB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHhtbG5zOnhsaW5rPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5L3hsaW5rIiB4bWw6c3BhY2U9InByZXNlcnZlIiB4bWxuczpzZXJpZj0iaHR0cDovL3d3dy5zZXJpZi5jb20vIiBzdHlsZT0iZmlsbC1ydWxlOmV2ZW5vZGQ7Y2xpcC1ydWxlOmV2ZW5vZGQ7c3Ryb2tlLWxpbmVqb2luOnJvdW5kO3N0cm9rZS1taXRlcmxpbWl0OjI7Ij48ZyBpZD0iRGVsZXRlIj48L2c+PGcgaWQ9IkFkZCI+PC9nPjxnIGlkPSJLbm93bi1Jc3N1ZXMiIHNlcmlmOmlkPSJLbm93biBJc3N1ZXMiPjwvZz48ZyBpZD0iQ2hhbmdlZCI+PC9nPjxnIGlkPSJGaXgiPjwvZz48ZyBpZD0iTmV3Ij48Y2lyY2xlIGN4PSI4IiBjeT0iOCIgcj0iOCIgc3R5bGU9ImZpbGw6IzNjOWFmZTsiLz48cmVjdCB4PSI0IiB5PSI3IiB3aWR0aD0iOCIgaGVpZ2h0PSIyIiBzdHlsZT0iZmlsbDojZmZmOyIvPjxwYXRoIGQ9Ik03LDRsMCw4bDIsLTBsMCwtOGwtMiwtMFoiIHN0eWxlPSJmaWxsOiNmZmY7Ii8+PC9nPjxnIGlkPSJOb25lIj48L2c+PC9zdmc+');
li.symbollistfix::before, li.checked::before {
content: url('data:image/svg+xml;base64,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');
li.symbollistchanged::before {
content: url('data:image/svg+xml;base64,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');
li.symbollistissues::before {
content: url('data:image/svg+xml;base64,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');
li.symbollistadd::before {
content: url('data:image/svg+xml;base64,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');
li.symbollistdelete::before, li.deletetask::before {
content: url('data:image/svg+xml;base64,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');
</style>
# Changelog
<ul class="symbollist">
<li class="symbollistnone">
NewText
</li>
<li class="symbollistnew">
NewText
</li>
<li class="symbollistadd">
NewText
</li>
<li class="symbollistchanged">
NewText
</li>
<li class="symbollistdelete">
NewText
</li>
<li class="symbollistfix">
NewText
</li>
<li class="symbollistissues">
NewText
</li>
</ul>
<br>
# Tasklist
<ul class="tasklist">
<li class="checked">
NewText
<table>
<tr>
<th>
NewHeader
</th>
<th>
NewHeader
</th>
</tr>
<tr>
<td>
NewRow
</td>
<td>
NewRow
</td>
</tr>
</table>
</li>
<li class="unchecked">
NewText
</li>
</ul>
[Edit]
I forgot to add the screenshots. For reasons unknown to me, not all icons are displayed in DEVONthink 3. If you use the css style in a css file and integrate it, there will be no display errors. I still have a screenshot of Microsoft Visual Studio Code there it works without any display errors.
DEVONthink 3.7.2
Iβd suggest to use external stylesheets rather than internal ones. Makes it easier to change the appearance for all documents if need be.
Also, Iβm not sure why youβd use HTML tables if markdown provides for tables as well. You could style them as well, I guess.
As to why some of your SVG items are not displayed in DT: do you see them Iβm a browser?
On a personal note: why do you even bother with markdown if what you really want is HTML with CSS?
BONSAI
September 20, 2021, 7:48pm
5
@chrillek this is just an example in which i am using HTML with CSS and is only part of the entire markdown file. As already mentioned, the icons are displayed correctly if you use the CSS styles in a CSS file and import it into the markdown files. This bug is not a problem for me because i use my CSS styles in a CSS file
BONSAI
September 28, 2021, 6:15pm
6
@BLUEFROG were you able to adjust the issue and find out how to change the header background color?
Not yet, but try using table th to set the color, not just th.
BONSAI
September 29, 2021, 5:21pm
8
@BLUEFROG thanks for your help, βtable thβ works very well
Youβre welcome.
Technically, the stylesheet shouldnβt require that specificity to target the table header, but itβs a simple enough workaround.
Cheers!
