Markdown editor in light mode
all text turns white and unreadable when there is a link in the markdown edit mode on DTTG on my M4 iPad Pro
Welcome @jdetrolio
I’m seeing no issue here in iOS 17.6 and DEVONthink To Go 3.8.6.
What OS and version of DEVONthink To Go are you running?
17.6 & 3.8.6
Do you use any custom CSS? And could you maybe share an example document that shows that behavior?
I don’t, but found doing a restart of the app and iPad fixed the issue.
Using DTTG a lot more now with shortcut integration and using markdown editor.
Only suggestion would be to add the cursor at the end of the note when editing from a shortcut.
Thank you for the suggestion!
