I need frequently used smart rules snippets to be called from within an ongoing other rule process.
There is a number of common rule actions I like to be part of many other conditionally triggered rules - like backing up the original name before renaming, logging the action to a log field etc.
Instead of the error prone task to insert and maintain these same sequences within many rules I would like to outsource them to a separate smart rule modules.
What did I try?
yes, there is a smart rule action
apply smart rule
– which however then passes the command to the new rule and never comes back to the original procedure. -
Next I tried to call the very smart rule “module” from an
execute script
action withperform smart rule
– the very called “sub”-smart rule would never be carried out- here via the
execute script :AppleScript
the called sub smart rule would never come to action - nor when via
execute script : external
using an external script in the smart-rule-folder - even when I then try to indirectly call a script to then
run script
another script to call the smart-rule, no avail
- here via the
but when I call the same rule from an external apple script it works fully like expected
Is DT preventing any of smart-rules sub calls?
This successfully prevents my automation
Am I missing out on something?
Is there any workaround?
Any Idea how to have a modularised smart-rule collection?
