The cause should be most probably the lacking of Growl on your system (that the script needs for reporting the outcome of the action).
Here is a copy where I commented out the reporting section
property pMove : "Move"
property pDup : "Duplicate"
property pRep : "Replicate"
property pDefaultVerb : pMove -- Default verb: may be switched to Duplicate (pDup) or Replicate (pRep) at run-time
-- ver 1.0 Allows double dot (..) as short-hand for parent group
-- (to facilitate moving selected records up one level in the group hierarchy)
-- ver 0.9 Fixed a big involving search strings which include a space
-- ver 0.8 Clarified the Growl message: bold header: [Verb]d [N] records to:, body:[Destination]/n[List of records]
-- ver 0.7 Enhanced the "Group not Found" message for replication to remind user that replication
-- is only possible within a single database.
-- ver 0.6 The default verb (Move) can be overridden by prefixing the search string with "d " or "r "
-- (for "Duplicate" or "Replicate") in LaunchBar or the standard dialog
-- (a single verb letter followed by a single space before the search string itself)
-- ver 0.5 Can get the search string from LaunchBar
-- ver 0.4 Allows target databases (where their names match) as well as target folders
-- (the default incoming group of the database is used as the destination)
property pVer : "1.0"
property pTitle : " to target group" & " " & pVer
property pstrDelim : " "
on run
set lstSelns to GetDevnSelns()
if lstSelns ≠ {} then
set strNames to GetNameList(lstSelns)
set strCmd to GetSearchString(pDefaultVerb, strNames)
if strCmd ≠ "" then
set {strVerb, strFind} to ParseCmd(strCmd)
if strFind ≠ "" then ProcessSelns(lstSelns, strNames, strVerb, strFind)
end run
-- GET THE TARGET GROUP SEARCH STRING FROM LAUNCHBAR
on handle_string(strCmd)
if strCmd ≠ "" then
end handle_string
on ParseCmd(strCmd)
set {strVerb, strFind} to {pDefaultVerb, ""}
set text item delimiters to space
set lstParts to text items of strCmd
if length of lstParts > 1 then
set strFirst to first item of lstParts
ignoring case
if strFirst is in {"m", "d", "r"} then
if strFirst = "m" then
set strVerb to pMove
else if strFirst = "d" then
set strVerb to pDup
else if strFirst = "r" then
set strVerb to pRep
set strFind to (items 2 thru end of lstParts) as string
else
set strFind to strCmd
end ignoring
else
{strVerb, strFind}
end ParseCmd
on ProcessSelns(lstSelns, strNames, strVerb, strFind)
-- CHECK THAT A KNOWN VERB IS SPECIFIED AT THE TOP OF THE SCRIPT
if strVerb is not in {pMove, pDup, pRep} then
tell application id "com.apple.systemevents"
activate
display dialog "\"" & strVerb & "\": unknown value for pDefaultVerb" & return & return & "Expected Move | Duplicate | Replicate"
return
-- GET FILTERED SET OF POSSIBLE DESTINATIONS
if strVerb ≠ pRep then
-- BOTH OPEN DATABASES WITH MATCHING NAMES
set lstParent to (incoming group of databases where name contains strFind)
-- AND FOLDERS WITH MATCHING NAMES
repeat with oDb in databases
set lstParent to lstParent & (parents of oDb where name contains strFind)
else -- OR, IN THE CASE OF REPLICATION, IN CURRENT DATABASE
set lstParent to (parents of current database where name contains strFind)
-- ALLOW FOR DOUBLE DOT (..) AS REFERENCE TO PARENT DIRECTORY OF SELECTED ITEMS
if strFind = ".." then set end of lstParent to first item of parents of (first item of lstSelns)
-- BUILD NUMBERED MENU OF DESTINATION NAMES
set lngParents to length of lstParent
if lngParents > 0 then
set lngDigits to length of (lngParents as string)
set lstMenu to {}
repeat with i from 1 to lngParents
tell item i of lstParent
set strName to (name of its database) & its location & its name
if strName = "Inbox/Inbox" then set strName to "Global Inbox"
set end of lstMenu to my PadNum(i, lngDigits) & pstrDelim & strName
-- CHOOSE DESTINATION
activate
set varTargets to choose from list lstMenu with title strVerb & pTitle with prompt strVerb & ":
" & strNames & "
to target group:" default items {first item of lstMenu} without multiple selections allowed
if varTargets is not false then
-- RETRIEVE CHOSEN DESTINATION BY NUMERIC INDEX
set my text item delimiters to space
set oTarget to item ((first text item of (first item of varTargets)) as integer) of lstParent
-- MOVE | DUPLICATE | REPLICATE SELECTED ITEMS TO DESTINATION
if strVerb = pMove then
repeat with oRec in lstSelns
move record oRec to oTarget
else if strVerb = pDup then
duplicate record oRec to oTarget
else if strVerb = pRep then
replicate record oRec to oTarget
-- NOTIFY RESULT BY GROWL (IF INSTALLED) OR WITH DIALOG BOX
my Announce(oTarget, strVerb, (length of lstSelns), strNames)
open window for record oTarget
activate
else
set strRepNote to ""
else
set strRepNote to "
(If you were attempting to replicate to another open database, note that DevonThink only supports replication within a single database)"
activate
display dialog "No open groups contain the string:" & "
" & strFind & strRepNote buttons {"OK"} default button "OK" with title strVerb & pTitle
end ProcessSelns
on GetDevnSelns()
return selection
end GetDevnSelns
on GetSearchString(strVerb, strNames)
set strFind to ""
-- GET SUB-STRING TO FILTER LIST OF TARGETS
activate
set strFind to text returned of (display dialog strVerb & ":" & return & return & strNames & return & ¬
"Enter search string to list target groups:" default answer "" buttons {"Cancel", "OK"} default button "OK" cancel button "Cancel" with title strVerb & pTitle)
return strFind
end GetSearchString
on GetNameList(lstSelns)
-- BUILD BULLETED LIST OF SELECTION NAMES
set strNames to ""
repeat with i from 1 to count of lstSelns
set strNames to strNames & "• " & name of (item i of lstSelns) & return
return strNames
end GetNameList
-- REPORT RESULT
on Announce(oGroup, strVerb, lngRecords, strNames)
tell application id "com.devon-technologies.thinkpro2" to set {strDb, strPath, strFolder} to {name of database, location, name} of oGroup
set strGrowlTitle to strVerb & "d " & (lngRecords as string) & " records to:"
set strGrowlBody to strDb & strPath & strFolder & "
" & strNames
-- USE GROWL IF IT'S RUNNING
if (count of (every process whose name is "GrowlHelperApp")) > 0 then
tell application id "com.Growl.GrowlHelperApp"
register as application "houthakker scripts" all notifications {pTitle} default notifications {pTitle} icon of application "DEVONthink Pro"
notify with name pTitle title strGrowlTitle application name "houthakker scripts" description strGrowlBody
else
-- (OR USE A STANDARD DIALOG)
activate
display dialog strReport & "
(This script works best if Growl is installed)" buttons {"OK"} with title pTitle
end Announce
-- GET A DIGIT STRING OF MINIMUM WIDTH (LEFT-PADDING WITH ZEROS WHERE NEEDED)
on PadNum(lngNum, lngDigits)
set strNum to lngNum as string
set lngGap to (lngDigits - (length of strNum))
repeat while lngGap > 0
set strNum to "0" & strNum
set lngGap to lngGap - 1
strNum
end PadNum
If you want you can add reporting based on OS X notification center.
