"move to" menu from shortcut difficult to read
When using the keyboard shortcut to move or replicate to a group, the selected option in the pop menu is hard to read (seen enclosed screenshot), at least for aging eyes like mine. My computer is not on dark mode, but the options that pop up seem to be in a dark mode style. Is there any way to modify that to make it more obvious which is the option selected?
(In the screenshot I’m replicating the pdf to the group “Cetacea”)
hm, p* > paraphyletic? :slight_smile:
I’m enjoying what you’re doing with the icons.
Yes, paralytic, good guess
Paraphyletic (damn autocorrect)
Welcome @juangut91
May I ask why are you prefixing the group names with a dot?
Because in some other areas of this database I need certain groups to not be necessarily on top in a list, so I unchecked in the settings to keep the groups on top; the groups I still want to remain on top of lists are prefixed with a dot
I do the same with an hyphen
Are you aware of the behavior in the Finder?
Not sure if I understand what you are referring to. I have my databases excluded from bein indexed by Finder if that’s what you are referring to.
No. Prefixing a folder with a dot would make it a hidden folder in the Finder. While there is no particular issue with this in DEVONthink, I wonder if your naming convention is a good habit to be in.
I did this as well, sometimes.
The next release will increase the contrast if the accessibility options Reduced Transparency and/or Increased Contrast are used.
