Dear all - especially you Jim! (hope all’s great with you) - I’m finding that using the “share” feature from Apple Notes doesn’t seem to be sending a note to DT. I can export a note as pdf, or share it to Yoink normally. I am attaching a screen of the share dialog. Any thoughts? Tx!
Hello, @uimike
When sharing a copy of an Apple Note, it is treated as textual content and it should open the Take Note view of the Sorter.
What version of macOS are you running? It’s working in Sonoma here.
Hey Jim! - Sonoma 14.5
strange, when i go to DT’s “Format” menu and select “Take Note…” nothing happens
Jim, what other Apple app shares to DT, just so I can test
Hm. Photos, Preview work fine - “Add to Devonthink” invokes the sorter
I haven’t been able to reproduce the issue so far.
Yep, a bit puzzling. I called the info dialog on Notes and it has a copyright 2023. Huh? Is yours the same?
ha, Preview is 2023 as well. Hey, they didn’t update the copyright to 2024!!
Yeah, just sloppy on the details
Just spoke with “them” - sounds like they will fix it ha ha
