I ran the script “Index–iCloud Drive”. Now I am wondering whether that was a smart thing to do.
–How does the database react if a file is removed from local storage but remains in iCloud?
–One subfolder in my iCloud is merely used as a backup destination for another program. It contains zip files only. Can I (Should I) exclude the subfolder from being indexed?
Ok, how do you suggest that I redo the Index so that it only includes the subfolders that will remain local? Should I delete the database that contains the index and start over?
Should I worry about Devonthink indexing zip files–I know it may introduce some overhead but seems harmless otherwise.
