Dear DEVONthink users
I use the actual version DEVONthink Professional Office 1.3.2 on a Mac OS X 10.4.10/PPC with German language settings.
As I did try a few weeks back, I thought I was able to set a backup path in the settings window.
Now with a completely new DB and/or with the ones downloaded from this website, I’m no more able to set the backup path.
If I use the script out of the script menu, I found after some searches a new folder called “Backup” inside my home folder.
Is this normal behavior and if YES, why did it work before; if NO, what’s the problem? I did a complete de-installation and new installation with deleting all files/folder I could find with the word “devon” in it. This way I did delete also any cache, preference and other related files. --> Hope so.
If anyone has some serious suggestions I would appreciate a response.
Best regards from Switzerland
Thomas
