Devonthink section links for markdown aren’t following the standard used in other apps for multi word sections.
Given the following markdown document:
[devonthink link](#1.lisbonportugal)
[standard link](#1-lisbon-portugal)
### 1. Lisbon, Portugal
The first link works in Devonthink, either in the document, or as an external link (x-devonthink-item://6FD7BF60-CDD4-422E-ACD2-9068C8EBD6BA?section=1.lisbonportugal
), but will not work in other apps.
The second links work in other markdown apps like Visual Studio Code and github, but do not work in Devonthink.
The other apps that I would say correctly handle markdown links, require that you remove all punctuation, convert to lowercase and replace spaces with hyphens.
Devonthink seems to require that you keep some punctuation (periods?), and requires spaces be removed.
Please support the more standard syntax for markdown section links.
