Hi there,
Is there a way to manage a search so that it only looks for answers not older then a year ?
Thanks for your help
Philippe
It’s the DEVONagent sub forum
Haha! Indeed.
@Philippe007 getting results from specific times isn’t simply done as it depends on the search plugins you’re using.
Here is a plugin for Google (Past Year)…
com.devon-technologies.google_pastyear.plist.zip (799 Bytes)
Unzip it and drop it into ~/Library/Application Support/DEVONagent/Plugins then launch DEVONagent.
Check Window > Plugins & Scanners for Google (Past Year).
Thanks for your help. It is exactly what I was searching. Furthermore I now have a better idea of what are plugins, where they are and how to use them. Thanks again
You’re welcome
