because of current events (viewtopic.php?f=3&t=11275) I want to express and emphasize the urgent need for the possibility to use in smart groups the following conditions:
item does NOT contain Tag A
item is NOT in group B
the best would be a general NOT operator available in every line of the smart group’s conditions
As a matter of fact, if you use the full Search window (Tools > Search) you can save any search as a smart group by clicking on the little “+” button to the right of the query field.
But it’s true that ‘is not’ is not currently available for tags in the Advanced search area or in the smart group editor.
But it’s possible to set up a procedure to exclude items (not directly in the smart group, but in another group replicating its contents) that have one or more specified tags. See viewtopic.php?f=3&t=11275&p=59546#p59546
Oh, you are right, it is possible! I started experimenting with the search window some time ago but found it too complicated for my simple uses. Now, as I am no longer overwhelmed by the DTP funcitonality, it might be time to give it another try.
