DT 3.9.1
The PDF resolution setting in the OCR dialog is not saved anymore.
Details:
Restarting DT does not resolve the issue.
DT 3.9.1
Details:
Thanks for the report. Can you open the Terminal application, copy and paste the line below and press Enter.
defaults write com.devon-technologies.DTOCRHelper OutputDPI -int 300
If you open the DEVONthink OCR preferences, is it showing 300 or “As Original”? If it is showing “As Original”, could you run the line below in terminal:
defaults read com.devon-technologies.DTOCRHelper
What is the value of OutputDPI?
Thanks, the write command worked.
But now I’m curious as of the output of the read command:
DPIPDFToImageConvert = 200;
OutputDPI = 300;
What is the first value?
Should I set that to 300 as well?
I’m curious what hardware you’re running.
macOS Monterey 12.6.4
on MacBook Pro 16’’ (2021), 1Apple M1 Max 10 core, 64 GB memory
