Recent Mac Book Pro with DEVONThink Pro convert.
Work E-mail software is Microsoft Outlook.
This means MSG files.
MDG file conversion is the only issue standing in the way of making DEVONThink the one and only PIM tool.
Majority of my Data is from Work E-mails (MSG files). Thus the need to have a reliable means to convert to a DEVONThink compatible E-mail file format.
Have tried the following for MSG to EML conversion:
1/ MSG to EML Converters
a) Aid4Mail
b) BigDaddy
c) InMediaKG
d) MailboxSDK
e) PST Converter
f) SysTools
g) TechHit - Messagesave
All of these apps have problems/errors in converting MSG to EML.
Embedded graphic/pictures/ole objects are stripped/removed during the conversion.
Questions 1:
Is there a reliable App which provides 100% reliable conversion of MSG to EML?
Question 2:
Is EML File format simply not compatible with data/graphics embedded in MSG?
Question 3:
Are there other E-mail file formats that can be used with DEVONThink for which there is 100% reliable conversion from MSG?
Thanks
