Hi,
I finally transitioned from DTPO 2 to DTP 3 yesterday. Glad to say it went a lot smoother than I feared – and the few oddities and problems that cropped up I was able to fix myself. Thank you so much to the whole team for all the terrific work you’ve put in!
One change from 2 to 3 is giving me a bit of a headache. I’ve simplified slightly, hopefully it’s clear what I mean:
I have a lot of articles and eBooks in my database. I want to be able to find these by their topics. So, in DTPO 2, I had a tag structure like this:
- Reading Tags
- Sociology
- Organisational sociology
- Bourdieu
- Communication
- Digitalisation
- etc etc.
So, when I assign a tag, say “Communication”, both DTPO 2 and DTP 3 display the parent tag “Reading Tags” in the tag bar at the bottom.
What has changed is the way Smart Groups handle this. In DTPO 2, I was able to find untagged articles and books by creating a smart group with the criteria:
Kind is PDF
Tag is not “Reading tags”
DTPO then wouldn’t show any documents with the tag “Communication”.
This no longer works in DTP 3, which still displays documents with the tag “Communication”. I think this is as a result of the much-discussed tighter Finder integration – the smart group search only looks at the tags applied to the documents which are also visible in the Finder.
I believe this is intended behaviour, in which case my question is: How can I find my “untagged” PDFs and ePubs without having to change the several hundred documents I have tagged in the last few years?
Any advice is much appreciated. Thanks a lot!
