I’m experiencing an issue with the built-in PDF reader in DEVONthink 4 (macOS Sequoia 15.5). When I open a PDF, the preview window launches at a small default size. If I manually resize it to a larger window and close it, the new size isn’t retained. The next PDF I open reverts to the original small window.
Steps I’ve tried:
- Resizing the window → Closing with⌘Cmd+W → Reopening another PDF (still small).
- Restarting DT4 + macOS.
Expected behavior:
After resizing and closing the PDF reader, future PDFs should open at the last-used dimensions.
Is this a known bug, or is there a workaround to force DT4 to remember the custom window size? Any suggestions would be greatly appreciated!
