It seems about once a quarter I have a syncing failure with Dropbox. Last Friday I added 44 PDF files (about 1.5 gb) to my 16 in MBP. It’s now going on 4 days and have still not sync’d with my MB12 or my iPad Pro.
As a test yesterday, I put a small pdf files on my MB12 to see if it shows up. In 24 hours it has not shown up on either my 16 or the ipad.
I seem to have a sync problem about once a quarter.
Any suggestions?
Thanks
Larry
As mentioned elsewhere, we are unable to reproduce any issue so far and we have also not changed any of the code regarding Dropbox sync in a long time.
Select the sync location in DEVONthink’s Preferences > Sync, control-click the problematic database in the Databases list, hold the Option key, then choose Verify Database Thoroughly.
What is reported in DEVONthink’s Window > Log?
DT3 has not been able to confirm such a problem (though they surely have tried) but clearly it exists. It does not seem to be consistent however in who or when it affects people, so it is quite frustrating in that regard.
It could be slow server responses from Dropbox. You can open a ticket - Option > Help > Report Bug and we’ll look at the logs.
