I want to print a RTF-File from DTPO with its Filename. Till now I only get the body of the notice printed. Is there a way to print the filename too?
Thanks
Peter
Thanks
Peter
Hi, Peter. No, you can’t do that directly from the TextEdit-based editor in DT.
But there’s a neat little freeware application, iTextExpress, that adds a few extras to TextEdit, including headers, footers and footnotes. If you install that, simply select and drag your text from the DT database (or copy/paste it) to an iTextExpress window, set formatting to wrap to page, and you can enter the file name as a header item, if you wish.
iTextExpress can be found at http://members.aol.com/iText/iTextExpress/TryiTxtExp.html.
