I’m looking for some advice. My workflow involves clipping articles to Instapaper and using my personal Instapaper RSS feed to import those articles in DT. Then I use a script to capture the paginated PDFs. The articles I save to Instapaper are usually in print view, to remove all the clutter.
There’s only one problem. Several months ago, NYTimes.com tweaked its settings so that anybody who tried to link to an article’s “print view” would be automatically redirected to the non-print view. (Basically if your link has the ?pagewanted=print string, it’ll be removed.) The non-print view is not very good for capturing PDFs. So the script takes print view links from my RSS and saves the non-print view.
Has anybody else run into this problem? I’m not really sure how to fix it, and I’d be curious if anybody had an idea.
Over here, the “print” button works as expected for NYTimes articles in DEVONthink.
… but, I’m a subscriber and logged into the NYTimes site, so the right cookies are set on my machine to let me around the paywall in all my browsers. Maybe this could be the limitation you’re up against?
Actually this has nothing to do with being logged in…I always get to view the articles, because I do subscribe, and I guess my login cookies are persistent.
The problem is, I never get the print view, just the regular article view. The difference can be a few 100kbs per PDF between print and non-print views, and that starts to add up. It’s mostly unnecessary content.
If you click this link you will not get the print view, even though there’s the print view string at the end, because the site automatically removes the string: nytimes.com/2011/12/28/worl … nted=print
I don’t know what “site automatically removes the string”. Clicked the link in DTPO. Clicked “Print”. nytimes.com asked me to log in. Logged in. As shown in the image, the view changed to print. The full URL is displayed. Over here, nytimes.com has always worked that way in DTPO.
Are you running any adblockers? Anti-spyware plugins?
What I’m describing is the fact that you can’t link to an article’s print view. It sounds to me like you had to take an extra step to print. The link I gave you was to the print view version of the article. If you click on any links to an NYTimes article with a ?pagewanted=print string at the end of the address, you automatically get redirected to the non-print view.
The problem with that is, if you’re using Applescript to turn links into PDFs, then all your links for print views will be turned into non print views. Those versions have photos and ads and create larger files that aren’t as convenient to read.
I was hoping maybe somebody had a suggestion for tweaking an Applescript, or changing my workflow. I have hundreds of bookmarks and I want to download copies for my files. The re-direct makes that difficult.
Presumably, NYTimes.com is checking the referrer on the URL.
DEVONthink’s AppleScript dictionary does contain download {markup from|URL|webarchive from} commands that allow you specify referrers. This should work.
Unfortunately, I can’t test it because I’m not a subscriber.
Can you elaborate a bit on that? I’m really not well versed in AppleScript and I can only tweak things. If the referrer for, say, nytimes.com/2011/12/28/worl … sters.html, can I tell AppleScript to do that using download {markup from|URL|webarchive from}?
I’m using Christian Grunenberg’s script (I might have tweaked it–I can’t remember), which I’ve posted below if you need to take a look at it.
-- Convert URLs to PDF documents
-- Created by Christian Grunenberg on Mon Mar 23 2009.
-- Copyright (c) 2009. All rights reserved.
if theSelection is not {} then
show progress indicator "Converting..." steps (count of theSelection)
set theURL to URL of theRecord
set theTag to tags of theRecord
step progress indicator theName
if theURL begins with "http:" or theURL begins with "https:" then
create PDF document from theURL name theName with pagination
hide progress indicator
In my testing (which was limited and annoying since I don’t have a subscription ), Christian’s script worked if you changed
to
create PDF document from theURL referrer theURL name theName with pagination
In other words, NYTimes doesn’t care who the referrer is so long as it’s on their site. Probably every website that does referrer checking works the same way, since the alternative (checking referrers against a calculated or stored list of all the pages on the server that link to the specified page) is a big pain in the neck and a big blow to efficiency with very little benefit.
Here’s a working version of the script, based on the original from Christian, @adro’s suggestions, and @ndouglas’s suggestions.
Try this script anywhere you want, but it will probably only work at nytimes.com
-- Print bookmarks or other documents that have URLs from nytimes.com
-- Based on: Convert URLs to PDF documents
-- Modified by Korm based on suggestions from adro and ndouglas
-- This is specific to NYTimes.com
-- and probably won't work anywhere else
-- You must be logged into nytimes.com for this to work reliably
set theGroup to display group selector
repeat with theRecord in (the selection as list)
set thePrintURL to theURL & "?pagewanted=print"
create PDF document from thePrintURL referrer theURL name theName in theGroup with pagination
[size=80]Feb 1, 2012 fixed code as @adro suggested, below[/size]
This works nicely as well. Although for me it required a small tweak (probably because NYTimes.com has changed things again): &pagewanted=print is now ?pagewanted=print.
