I ran into an issue fairly recently, but has happened periodically in the past as well. Basically I have two problems right now:
- Some sites, when clipping to DevonThink, only import a blank page.
- Example: hpbn.co/transport-layer-security-tls/
- Another Example: docs.microsoft.com/en-us/nuget/ … g-packages
If possible, could someone else try these and see if they get similar behavior? I’ve had decent success importing as a web archive, but the problem with web archives (for me), is that often times I want to add my own documentation to it. For example, on the nuget one (2nd link), I want to add information about missing references as a use case for this. PDF works really well for me, especially since I can annotate them on my IPad Pro (which I do a lot of)
- I think my database is somewhat corrupt, but do not want to revert from a backup. Especially since the backup could be a day or so old. I can still open the database file, and work with most items in it just fine but in Example 1 above, I tried to download it as PDF again and now if I try to delete that entry, it will cause DevonThink to crash. I had to run a “Rebuild Database” to get it working fine again.
