Hi
I keep a database of vCards imported from the Apple Contacts app on my Mac. This is a backup really, I do this usually before I sit down and have a purge of contacts. So this evening I imported all the contacts as vCards and I have discovered that none of the notes is included, the note field is just empty in the vCard in DT.
I know that it used to work because I have the ones I did the last time, in 2020 actually and all the notes are present in those.
I do keep a lot of useful info about each contact in the notes so I do want to have this.
If I import them as a sheet, then the notes are present. However I prefer them as vCards.
I have DT 3.9.14 and my Mac has OS 15.6.1
Thank you for any assistance you can provide.
