Please help me. My workflow no longer works. Maybe this has something to do with updating to the latest version of iOS? I urgently need to find a solution. Please help me.
I organize my PDFs in DTTG. To read a PDF and annotate it, I use PDF Expert. So far this has always worked well. In DTTG I have selected the PDF, I have selected “Share”. The PDF was opened in PDF Expert, I annotated it there. When I was done, I’m on “Share” in PDF Expert, selected DTTG there. Then DTTG opened automatically and showed a message “Object actualized”. That doesn’t work anymore. If I want to actualize the annotated PDF to DTTG, to apply the changes, a copy is always copied there, but not the old PDF actualized. When I select “Share” in PDF Expert (and as always before file format “Original document”), then DTTG, a selection “Clip to DEVONthink” appears. This selection window “Clip to DEVONthink” never appeared so far, the PDF was simply actualized instead. When I use “Clip to DEVONthink”, a copy is copied to the selected location in my DTTG database. Since I have replicas of all PDFs, replacing the old versions with the annotated ones is very time-consuming.
Also new to me: When I select a PDF in DTTG and select “Share” in the menu that opens, there is a text character in the upper left corner next to the title of the PDF with cursor as symbol, when I click on “Open in…” in the menu, it changes to a PDF symbol. I don’t see the difference for “Sharing”. But regardless of what I choose here, the problem described above always occurs.
I’m really asking for help. Hopefully my English is fine. I use the German UI. Many, many thanks!
