I recently updated DTTG on iPadOS following an App Store prompt. I presume it was to DTTG 3.7.5. On starting the new version it said it was updating the database, which took several minutes. The app then vanished (crashed?). Since then, the app appears very briefly showing the logo when started and then crashes.
I uninstalled DTTG (which removed the data) and reloaded it from the app store. It then started fine and I was able to set up sync with DEVONthink on my iMac (direct sync over local network). Shallow sync with two databases appeared to be working fine. When I turned sync on for a third database, DTTG crashed immediately. That database appears fine on the iMac where I have closed and reopened it. The database size is 36.5 GB.
Yes, 74 GB free and I tried to do shallow sync (metadata only) for a database which is 36,5 GB on the iMac. This database was syncing fine prior to the DTTG update.
I’ve just submitted a crash report, but I specifically triggered the crash by using the share sheet so it might not be the same bug as reported here, though it sounds very similar.
To be honest, I’m also not entirely convinced it wasn’t the Highlights app that caused DTTG to crash as I’d not had any problems with DTTG and iPadOS17 until I tried to open a PDF externally. I am unable to troubleshoot it though as the share sheet button will no longer work even if I hard close DTTG (pressing it just crashes DTTG again).
I am also having problems with DTTG crashing on iPhone, iOS 16.7. Had the same trouble with 16.6. I see the DT logo for a few seconds then the home screen reappears.
From this thread I see that maybe the problem is lack of space on my iPhone? There are about 30 gigs of free space on it. Maybe that is not enough, and causing the app to crash?
