I regularly use the devonthink sorter to take a screen shot. Todayu I was trying to do that over a sketched drawing of a blog and it took the picture but now that picture is in the sorter and it will not complete the transaction. I have exited devonthink, even switched machine off but when I boot up and load devonthink it contues to be there this means I can’t use the screenshot tool for devonthink. When I use the ordinary MACOS ascreenshot it works normally and loads the screenship automatically to my devonthink in box. Is there a way to get devonthink to purge that particular picture and resume life as a screenshot tool?
I am running DEVONthink 4 and the same thing has happened. I removed the offending file buit when I try to go to the sorter the screenshot app still shows the wallpaper for Sequoia
I may have fixd it inadevertedly. It is working ok now. I tried taking screenshots in the normal shift-comand-4 way and that seemed to do the trick. Sorry to bother you
