Hi,
I have a problem with script.
In Devonthink 1.8 user manual on page 7 is following.
Installing the script "Save to Devonthink"(…) into ~/Library/PDF Services (…) and then printing any document directly to Devonthink as PDF.
I have copied the script in a new created folder (PDF Services) in my home directory hd / user / myname / PDF Services.
I don’t understand in which way I can use this script
Jochen (.de)
You can use the print command when viewing a web page or basically any other file (word, excel, jpg etc) and choose save to devonthink from the pdf menu/button at the bottom of the print sheet.
The pdf button will have an arrow on it. You can select that button and then select from a menu of options, including saving the file directly in DT as a pdf.
have fun
Thanks
but maybe i’m stupid.
I have open this site in safari with 10.2.6.
I make PRINT and then I see the PRINT menue with:
Preview (Vorschau)
Save as PDF (Als PDF sichern)
Cancel ? (Abbrechen)
Print (Drucken)
There is no …and choose save to devonthink from the pdf menu/button at the bottom of the print sheet…???
Jochen (.de)
have you logged out and back in (You may need to restart the machine, but I think a logout/login is all you need)?
Yes,
I have logged out and logged in.
Is it sure that this directry is right??
/Users/hansjoachimklotz/Library/PDFServices/Save\ to\ DEVONthink.app
Can somebody send a screenshot about his right menue?
Jochen (.de)
sjk
March 9, 2004, 11:15pm
#6
Make sure it’s PDF Services , with a space in it.
The About these scripts & macros file in the Scripts & Macros directory of the distribution says:
You mentioned you’re running 10.2.6; do you have an installed printer?
Hey Thanks
The solution was the missing space in PDF Services
Jochen (.de)
