Hello, I’m still using DT Pro Office 2.11.3, syncing via iCloud. I just bought a new MacBook Pro, and after using the migration assistant, opened DT. Everything in my database appears, but the log is now showing two errors:
The file “master.plist” couldn’t be opened. NSCocoaErrorDomain 256
The file “DEVONthink” couldn’t be opened. NSCocoaErrorDomain 256
These errors will repeat if I leave the app open. Any help would be greatly appreciated!
I figured it out, so in case anyone else in the future has the same problem, the solution was to go to System Preferences > Security & Privacy and enable DEVONthink in the “Full Disk Access” section.
while the errors mentioned above occurred for me in a completely different context, the solution still fixed my issue. Just wanted to point that out for anyone searching the forum by this error code.
Thanks for the follow-up and assuming you’re running DEVONthink 4.x, check out the Getting Started > First and Last Steps section of the built-in Help and manual for information on macOS’ Privacy & Security settings relative to DEVONthink.
