I tried using DTPO over the weekend again and it’s still not working reliably. I’ve had a number of problems including:
- Indexing taking forever, DTPO stops responding, reboot, rerun DTPO, 0 files indexed.
- Same problem with import: 0 files imported… folders and subdirectories are imported, but they are empty.
- Crashing (stops responding) when try to “run” the app.
- Have to reboot Mac over and over again to continue.
- Copying data from one DB to another doesn’t work.
- Seems the database is too “fragile”, meaning that if you do something wrong… or if you forget to do something, you risk corrupting the database. The only remedy seems to be to hope and pray that you have a backup (outsider DTPO, and “before” DTPO).
- Rebuilding the database leads to 1,000s of “Missing File” and “Failed” error messages.
- Importing gets stuck on file 759 of 38,946. Goto #4.
- Verification step finds 2 inconsistencies, 0 incorrect checksums, and 3,941 orphaned files. Then when I go into see the database, the orphan folder (AKA group) is empty.
- In the sidebar, next to the database names was displayed an icon that looked like an “X”. Zooming in on a print screen, it looks more like a pencil with a line through it / crossing it out. What does that icon mean, and how do you fix it?
This Mac has 4GB RAM. I’m using dtBase2 databases that range in size from 1MB… 700MB… 8GB… and up to 14GB. I’ve made lots of copies of the databases, and then I work on that copy. When that copy gets bad enough, I file it away and try again with another database. I think I need to throw these databases away and start over. Problem is, I’ve been doing that for a month now.
The latest problem is that after trying to rebuild the biggest database (14GB) now when you click on a file, it shows the file “name” in pretty grey font, instead of the content. The files look like they are “there”, but they are “empty”. What caused that, how do you fix it, and how do you prevent it?
Some of my databases are on the internal drive, others are on external drives, and networked drives. Can DTPO handle databases on different disks?
Some of these disks are / are not indexed by Spotlight. Does Spotlight indexing affect whether or not DTPO works?
I would like to go on and dump more files into DTPO, but I’ve got to figure out how to make these smaller databases work first.
Am I the only one running into these problems?
I want to be your biggest fan. I see the potential for how DTPO could help tremendously simplify and speed up some of my work. This feels like a power tool that is dangerous in the wrong hands, but promises to be extremely powerful once you learn how to use it correctly.
