So my workflow has been to open articles in my dttg database in Acrobat because I prefer their annotation tools. Now it does not seem to work. When I hit the open in command from the share sheet nothing happens. Used to work fine before
I am not seeing any issues here. In DEVONthink To Go, select Help > Contact Us to start a support ticket. Also provide any more helpful information, screencaps, etc.
The way i do this, normally works:
When opening a PDF in DTTG, you can then use the “Share” button.
The “Share” button shows two rows:
In the first row, i can use “Copy to” for lots of Apps, incl. LiquidText, MarginNotes Pro, PDF Viewer and PDF Expert.
I tested them to be OK.
But this is not what we normaly need with DTTG, those Apps shall open the file from within DTTG, so that when i made changes, the changes are written back at the same place!
For this, as much as i understood, is this second row of the “Share” button.
Here, i can use “Open In …”
“Open In …” again shows two rows.
In the first, there is again only “Copy to” available.
And in the second row, i can only see “Import to PDF Viewer”, no other App.
This correctly opens my PDF folder in DTTG, i can annotate the PDF and back in DTTG, i can see the changes!
Perfect.
But then, there is only “Import to PDF Viewer” available, but i also need the others!
So, for them, i normaly did this:
Open the App itself, navigate to the File Provider “DEVONthink To Go”, open the file, annotate it, …
This works at least for PDF Expert Pro.
But is does not work for LiquidText - it seems to copy the PDF instead.
And in MarginNotes Pro, i cannot even open other File Providers.
There is no comment and no fix.
It seems to be hopeless.
You dont actually work on the iOS version.
