Not with all pdfs, but I’m having a problem with some. From the print dialog box, if I try to Save to DTPO or Save as PDF, the html links are not preserved. If I just save as a PDF, not using the print command, the links are fine. Is it just me, the PDFs in question, or a Leopard issue?
That’s an issue of Mac OS X, e.g. use the print dialog to save this as a PDF document and the link will disappear too. Obviously Mac OS X doesn’t use the original PDF document.
I played with this some more and it appears to be an issue with Mac OSX with print to PDF when the PDF is displayed in Safari. I was able to reproduce this from another unrelated site. I suppose the expected behavior is to open the PDF in Preview and save from there (which preserves the links). I’m sending Apple a bug report.
