Hello,
I think I may have found a bug with the Clip to DEVONthink bookmark.
Problem: When I Clip a webpage to PDF (paginated or one page) to DTPO and it has a period character in the title, any text after it does not appear in the file name in the Finder (using reveal in Finder), but only in DTPO. This is a problem because when I export my files from DTPO to the Finder, any text after the period character is missing (thought it displays in DTPO).
Troubleshooting: I tested this further with capturing to a Plain Text, Rich Text, Bookmark, Formatted Note, HTML Page, and Webarchive and all the text is retained after the period character in both DTPO and in the Finder. So it seems that the problem is exclusively related to capturing PDF’s.
This is a big problem for me because I capture almost exclusively to PDF, and to know that if I ever have to export my entire database some files will loose important file name data. Is there a script or some other method that can change the actual file names in the Finder to the file name as displayed in DTPO?
Also, can anyone else confirm this behavior? I’m on OS X 10.11.6 and running DTPO 2.9.8
Darryl
