Hi,
Long time reader, first time poster.
I had a setup where I could scan documents with my ScanSnap iX500 into a folder called “Inbox” (/Users/“username”/Library/Application Support/DEVONthink Pro 2/Inbox) from where DevonThink Pro Office would pick up the document and automatically OCRed it.
Since update to MacOS Sierra, latest update of ScanSnap software (I was waiting for the pdf fix upon your warning) and DevonThink Pro Office 2.9.7, this does not work anymore. When I start scanning, DTPO launches and the I get the following messages:
Document at path /Users/“username”/Library/Application Support/DEVONthink Pro 2/Inbox/2016-11-20-13-18-09.pdf” does not exist!
Can’t import PDF document at location: Inbox (You can try to inspect the document in the Finder and try to import it from there.)
after which the document is imported into DTPO, but kind is “pdf” (small letters) and an OCR cannot be performed. Only after dragging the file onto the desktop and into DTPO again, kind changes into “PDF” and OCR can be (manually) be performed.
How can I get back into the flawless scan, hand over to DTPO and OCR the PDF?
Cheers,
arne
