Problems with "Show in Finder"
I am using DEVONthink 3.9.3 on a MacBook Pro running Ventura 13.5.2.
Since a few months, the “Show in Finder” function no longer works. When I right-click on a file and select show in finder, a finder window opens, but it does not show the selected document in its directory, but it always shows only my home directory.
Please help! Thanks!
Is a verification of the database successful? And do you use indexed or imported items?
I use imported files. And I verified the database and checked integrity - all good.
Where is your home directory?
What do you mean? It is /Users/vollmer, and the databases are in /Users/vollmer/Documents/Devon/
And is the home directory on the internal boot drive?
Yes, it is.
And as said above, it worked fine until 3-4 months ago.
What changed on your computer 3-4 months ago?
Hold the Option key and choose Help > Report bug to start a support ticket.
I use Show in Finder often on pretty much the same setup as the OP. Show in Finder works fine for me.
Indeed, it’s not a widespread problem.
I have just started experiencing the same problem. Selecting “Show in Finder” on any file in DevonThink opens my home directory (Computer/Harddrive/Users/sroka) instead of the director of the file. I have tried verifying and optimizing the database, to no effect.
Curious if you ever found a reason for this?
I’ll send you a bug report.
Where is the file actually located? Do you use a Finder alternative like Path Finder?
Ticket forwarded to you. Desktop and Documents are local.
  • Are you indexing files into the database?
    • If so, from where?
These are RTF files created in DevonThink. So, they are stored within the database.
I’ll reply to the support ticket. Thanks!
