Hi, I thought I had a bug in testing DTTG but on digging it may be an issue with different sync stores… see attached screenshots.
(note using DT3 version 3.5.2 and DTTG version 2.8 (16448)
I sync databases to my iOS devices, iPad Pro and iPhone.
The only real database I add stuff to on both is the one called iPad-iPhone. I began to notice things weren’t syncing… so did a few test text file adds and it confirmed no longer syncing…
Then I did a bit of digging - the iPhone seems to sync to a store called DTP-Drobox-sync.dtCloud, and my iMac seems to sync to DTP-Dropbox-sync.
Don’t know how I did that but it seems ive created two different sync stores…
is there any way I can re-sync these databases? Or do I need to export the iOS one, delete it and then re-import either in the Mac or on the phone?
OK, I don’t know what I’m doing wrong but it seems my databases are all synching to the sync store but none of them seem to update the others…
See screenshots below, all from the Inbox/iPad-iPhone sub inbox
the problem exists in the iPhone-iPad inbox (which is shown as a subset of the master inbox) but also in other databases.
for example, I have added test text files in the root of iPhone-iPad and also in a database I have for serial nos / software licences and also in a new database I created on Mac for photography…
also in iPhone-iPad database my iPad shows 49 orphaned files which are not orphaned in my macOS database.
I have noticed some strange behaviour on the iPad (running test flight betas on both iOS devices) where, on my iPad Pro, the splash screen can take minutes to get past the DT logo!
And I occasionally get error messages when I force a resynch but when I try it now I can’t replicate the error to get a message. Will try again and post if if it appears.
I am running into the exact same problem here, on both my iPhone 8 and iPad Pro, both running 14.0.1.
Sync works well for all the normal databases, but the Inbox database does not align between the two iDevices and the Global Inbox on the Mac running DT3.
I ended up moving individual notes to the Inbox of a different database to move the from the iPhone to the sync’d database, but since the inbox does NOT seem to support a quick way to select all the items, I have stopped wasting time moving them in chunks, as I am talking about 830 items!
There is clearly something wrong going on in both iPhone and iPad.
I see mention of a TestFlight build 2.8, but the OP @joe.lafferty seems to have been using it and still facing the issue.
@cgrunenberg@BLUEFROG please let me know how I can make sense out of this nasty situation, as I really want to get all my DT3/DTTG devices aligned.
Could it be that I am running into the pesky Dropbox issue that few are facing?
I don’t get any weird messages on DT3 on my Macs, thought, and the global inbox syncs fine on the two Macs.
It’s just that the iPhone and iPad seem to have disjointed inbox, which don’t sync at all, in spite of having the sync correctly configured, apparently. Go figure.
BTW as an additional maybe useful bit of information, when I changed to iCloud for the inbox sync, all the devices, DT3 and DTTG, came up with a message saying that some 4 items could not be synced.
Hello folks, I think this is the correct thread to post an observation and concern I have. Today I opened DevonTHINK To Go on my iPad running iOS 14.0.1 and noticed my locally synced databases all had counts of 0. My heart jumped when I tapped each database to view their expected previously synced contents: there was nothing at all listed or showing in any of the synced database. Yikes! I hadn’t seen this happen before, and am wondering if it might be an iOS 14 or iPadOS 14 issue? Or did something nefarious like a zero day on my iPad siphon my data out of my synced DTTG databases? For DTTG on my iPad I have biometric protection enabled and purchased the Pro Package. I only local sync with a Mac on my local network, the syncing option is to download as full files. There is no WebDAV or third party cloud involved.
As my heart was racing, I turned my Mac on and opened DEVONthink 3 to check everything was fine (all good, all databases are there) and then re-synced from the iPad. The re-sync seemed very very quick so I wonder if my synced databases on the iPad were there all along but hidden? Could there be a bug related to iOS 14 / iPadOS 14 displaying the contents of synced databases? Additionally and possibly useful: I haven’t used DTTG on the iPad in quite some time, maybe a week or two or three, I don’t recall exactly but it has probably been at least a few weeks since installing iPadOS 14 in mid September 2020. Is it possible by not opening DTTG for a while, if DTTG remains in “dormant" state unopened / unviewed for an extended period of time, could this lead to an issue related to what I observed today? Further to note, I have never installed any betas of iPadOS. I installed Apple’s public release of iPadOS 14 soon after it first came out in September of this year. For DTTG on the iPad I enabled in Settings both Local Network and Background App Refresh. Thank you for any thoughts or suggestions on these observations.
