Questions regarding Prism integration
Is it possible to set the language type in Markdown on indented code blocks? I’m able to do this with ``` blocks, but can’t figure the other out.
Also, is it possible to change the prism theme?
No, this is not possible.
Not directly no.
You could always make your own stylesheet and set as the Preferences > Files > Markdown > Style Sheet with your own overrides.
As an example with internal styling for testing…
