Was hoping that Devon Sync was answer to my prayers. Sadly not.
I have verified and repaired all of my databases prior to sync from Desktop to DropBox API sync.
When I try to import one of my databases named “Work” (guess what that is for) Devonthink Pro Crashes every time.
I have deleted Devonthink from laptop and reinstalled with same result.
I have deleted DropBox App/Devonthink folder, rebuilt work database, verified and rebuilt work database, started fresh sync to DropBox through API and I STILL get a crash when I try to import the database.
I need more direction and I am not sure where to go.
This will log more detail to your system log, which can be viewed in /Applications/Utilities/Console.app.
After you’ve attempted the Sync, open Console, type “DEVONthink” in the filter field in the upper right-hand corner, and copy and paste ALL of the window’s contents into a new text document.
