I use DT Pro to track my genealogy research. I just ran into a problem where replicating replicates the entire group rather than just the single item in the group.
Here’s the background.
- Using DA I download census images into DT Pro as PDF + text
- If there is more than one family of interest I duplicate the page as many times as necessary and rename the original and any duplicates in this format - i.e. 1880-Ohio-Henry-Ridgeville-Wolf, Jacob and the next as 1880-Ohio-Henry-Ridgeville-Arps, Herman etc. The name at the end is the only change.
- I move each of the images into a group called 1880
- I replicate the Jacob Wolf image into separate groups for each family member listed and do the same for the Arps image, etc.
This seems to work fine for 3 images or less in the 1880 group. Once I try to replicate image number 4, the replication process replicates all the images in the group labeled 1880 even though only one of the images was selected.
Any ideas?
